Only 3.31 ratio?
Only 3.31 ratio?
So I was building a 2011 superduty on the ford website the other day and noticed that the 6.7L diesel only comes with a 3.31 gear ratio option. Hmmm, I know they got the 6 speed trans and a lot of grunt in that 6.7L but 3.31 really? Is this where their big fuel mileage increase with the 2011s is coming from?
Just went through the build process myself. You can get a 3.55 locking rear with the 6.7, but not 3.73 or 4.10. My guess is possibly with all that torque that it would require to high an RPM on the engine with those ratios.
Yeah I'm not an expert, but I would guess that the 6.7L diesel with 800lb-ft of torque at 1600 RPM doesn't need to be geared as low as the 6.2L gas which has 405lb-ft @ 4500 RPM
http://www.fordvehicles.com/trucks/s...ations/engine/
Yeah your right, my bad. But you can get 3.73 in the 350 if you go with the DRW f350.
