60K maintenance
Old Apr 27, 2010 | 08:05 PM
rodneygc's Avatar
60K maintenance
Okay,
So I don't want to pay $639.00 to have someone else do the fluid change and all that on my truck, where are the lube points on the chasis? How do I change the differential fluid, tranny fluid, the transfer case fluid, grease steering linkager, ball point? What fluid do I buy, what's the best kind of fluid to use for each?
Old Apr 27, 2010 | 10:44 PM
maddoughboy's Avatar
Well I don't believe your truck will have lube points unless something has been replaced. your diff wuld depend on what one you have weather it is a drain plug on the bottm or you might have to remove the cover by removing all the bolts on the back (this is most of the f-150) "T" case is a drain and fill. and I would take it some were to do the trans since most of the news ones you have to have speacial tools to do this. Look in your owners manual for what fluid you have to use.
