limited slip help
alright fellas im in need of some help im wanting to change out to a limited slip and so the question is are they measured like ring and pinions or something different any help would be great thanks
You can re-use your ring gear and pinion. If you do not disturb the pinion by replacing the pinion bearings, you do not have to worry about pinion depth when setting the gears back up. Measure the backlash before disassembly with a dial indicator and make sure it is the same afterwards. But, depending on the miles on your truck, it may be a good idea to replace all of the bearings and pinion seal.
This is a job best left to the professionals if you don't know how to do it.
Go to Summit Racing and buy the Richmond Gear video that shows how to change out gears if you are inclined to do it yourself. The video is about $15. Even with the video, I don't recommend you try it yourself unless you are very meticulous and mechanically inclined.
On a related note, I have a 9.75" 3.55 LS and I'm wanting to go to 4.10 gears. The same LS chunk should work with the new gears, right? Or would I have to buy a new LS or locker?
That would add too much cost, and I probably wouldn't do it then.
Last edited by ucfperspicere; Apr 9, 2010 at 11:56 AM. Reason: added my ring gear size
