Help. Noise coming from front end
Old Aug 24, 2000 | 09:45 PM
Bob's F150's Avatar
Post Help. Noise coming from front end
This is a noise that has occured now at least 12 times in 23,000 miles. It sounds like your going over a rumble a strip at highway speeds but happens only in a turn and at low speed. An example was this evening pulling into a parking lot the noise occured and vibrated the floor. The only thing I can think of is either the one of the front hubs or the differential. I am going into my dealer tommarow to tell them about it but I'm sure they will tell me that if I can't repeat the noise they can do nothing about it. Has anyone experienced this????????????
1999 F150 S.Cab 4x4
Northland Edition,5.4
Off road pkg. Fleetside
Black w/grey int.
[This message has been edited by Bob's F150 (edited 08-24-2000).]
Old Aug 25, 2000 | 09:59 AM
michael_hovis's Avatar
Post
There may be a tsb, here's the link for the list of all tsb's for your truck:
http://www.alldata.com/TSB/20/992017DE.html
Specifically, look at 99-14-3.
Model: '99 F150 Lariat Supercab 4x4 SS Mechs: 5.4L, 3.73 Diff (9.75" LSD Rear, 8.8" Front)
ORP: Skid Plates, LT265/70R17 GY Wrang. AT/S
Group III towing: HD Electrical/Cooling, GVWR 6500# (Extra leaf spring).
Stuff: Step Bars, 4W Disc ABS, K&N filter, 0W-30 Series 2k Amsoil @ 8200 miles, Herculiner
Stock Items That Differ Across F150s: Steel Driveshaft, Oil filter bolted to engine w/ drip guard, 4R70W transmission.
Old Aug 25, 2000 | 09:07 PM
Y2K 7700 4x4's Avatar
Post
Nice link - Thanks, Mike.
Old Aug 27, 2000 | 10:32 PM
Bob's F150's Avatar
Post
OK I went to the service department and read the TSB that Mike linked to. (Thanks Mike) It sounds like I would need an entire 3rd member rebuild. My question is what could I be getting into if they do the work. Other problems that is. Because it seems that once you take something apart from the factory it never seems the same. And if I left it until my warranty is about to expire what other residual damage could it cause. Do you think the front end could lock up??? Thanks.
1999 F150 S.Cab 4x4
Black w/grey int.
[This message has been edited by Bob's F150 (edited 08-27-2000).]
