4.56 vs 3.55 gears?
Old Nov 24, 2009 | 11:21 AM
bigliftbb's Avatar
4.56 vs 3.55 gears?
If I were to swap my 3.55 gears for 4.56's, would this cause an increase in the fluid temp in the pumpkin? Does this fluid need to be changed more often? I have a lifted 2006 Screw with 35" tires and need to swap out my gears for towing. I already use a synthetic gear fluid. Any info would be much appreciated... Thanks
Old Nov 24, 2009 | 08:29 PM
chiefFX4's Avatar
i think the change in heat produced is negligible.
as with anything it's always good to keep an eye on things, but you can still follow regular maintenance schedules.
if it really bothers you then look into a mag-hytech diff cover.
Old Dec 2, 2009 | 05:15 PM
mav015's Avatar
it doesnt get much hotter iv had the gears for alittle bit and everything seems fine everyone i talked to said is the heat its much different at all from 3.55 and im at 4.88 so you will be fine
