adding 4x4
Old Oct 16, 2009 | 01:40 AM
d_dyer's Avatar
adding 4x4
I want to add 4x4 to my 88 f250 and i want to know what i need. I know this probably sounds crazy but i am tired of getting pulled out of the mud pit
I am wanting a Dana 60 front end if Dana makes them for Ford.
Thanks!
Old Oct 16, 2009 | 04:25 AM
bigred1227's Avatar
dont go muddin in a 2wd lol!!!! ummm look for conversion kits cus idk i have the same ?
Old Oct 16, 2009 | 04:57 AM
d_dyer's Avatar
I found that out the hard way, Getting stuck sucks! I don't even have to be muddin to get stuck, found that out yesterday
Old Oct 16, 2009 | 11:58 PM
d_dyer's Avatar
I looked around today and i think i may have it figured out.
1.Dana 60 front axle, Manual Hubs
2.Front drive shaft
3.Transfer case for C-6
4.Spacer thing (between transfer case & Transmission)
5.shorten rear drive shaft
6.shifter
Is that all i need? Will my 2wd front suspension (springs, shocks, etc.) fit on the Dana 60?
Thanks!
Old Oct 18, 2009 | 05:31 PM
chiefFX4's Avatar
i believe converting to 4wd on that model year is just swap in an axle and add transfer case, etc.
the stock front suspension will work. some things on the dana may need to be changed (spring perces, shock mounts). not certain on that though.
Old Oct 18, 2009 | 05:57 PM
d_dyer's Avatar
I heard a Dana 60 from a 88 to 96 f250/f350 will swap out without any cutting or drilling, Is this right? If i have to go with leafs on the front it isn't that big a deal, Coil springs will probably give a better ride though.
Thanks!
