5.4 replacements?????
Old Oct 13, 2009 | 11:01 AM
blanco lobo's Avatar
v10 in a f150 questions?????
a friend told me that a triton v10 would bolt right up to my existing tranny in my 05 f150. i'm not buying it. am i right?
Old Oct 13, 2009 | 11:10 AM
4.6 Punisher's Avatar
A 2 valve motor will not bolt up without a lot of modifications. Even if you got it in, you would still be taking a 40 HP hit. Have your engine rebuilt if it's getting worn out.
Old Oct 13, 2009 | 04:28 PM
JimmysotherFORD's Avatar
there is a 3valve v10.
Old Oct 14, 2009 | 01:34 AM
Yeah, but there was never a 4R70/75 offered with it - just a 4R100 or 5R110.
Old Oct 15, 2009 | 06:51 PM
Tornadom's Avatar
If you could mate a 3v v10 to your existing transmission, it would hate you for doing it! Not that the Triton V10 is a monstrous powerhouse, but the 5.4L is already at the upper end of the 4r70/75 transmission's comfort zone.
I'm sure the extra cylinders would make for a tight fit in the F150 as well.
Old Oct 15, 2009 | 07:50 PM
05RedFX4's Avatar
All modular engines use the same bellhousing bolt pattern so any trans that was originally bolted to a 4.6, 5.4, or a v-10 will fit. They also all use the same motor mounts, but the v-10 block has them mounted upside down and backwards (the passenger side goes on the drivers side and upside down and vise-versa) Also the 2v and 3v v-10's use the same block, the only difference is the pistons (the dish is cut or cast in a different shape for the 2v versus a 3v).
Swapping a v-10 into an 04-08 150 can be done but it would depend on what style v-10 you decide to use and what trans you use, the 2v models had a 4 speed auto in the earlier models, while the later 2v's had a 5 speed auto and the 3v's all had 5 speed autos. If you swap in a 2v engine, you could theoretically use a older super duty pcm w/a 4r100 trans and just change the pinout for the trans to make it work w/a 4r70/75. Now if you use a 3v v-10 then you will need a super duty pcm from 05-up and either make the 5 speed trans work in your truck or somehow figure out how to get a pcm for a 5 speed auto to control a 4 speed. You could also do a manual swap because both versions of the v-10 had a manual trans option. If you switch to an e-fan setup you will have just enough room to get a v-10 in there.
If you decide to add more performance to the v-10, you can have your v-10 heads CNC ported just like the 4.6/5.4 heads, cams will have to be custom billet pieces, forged pistons and h-beam rods are the same pieces for a 5.4 JPC racing makes a sheetmetal intake manifold for the 4.6 3v engine and it can be easily widened to fit a 5.4/v-10 and can be extended to add the two extra cylinders of the v-10. I've never seen a production roots or twin screw S/C that is made for a v-10 but you can use a centrifugal type S/C on them.
