Popping/Vibrating!!!
Old Oct 10, 2009 | 12:28 PM
Jr_WaxDr's Avatar
Ok, heres the problem. My truck just started making this crackling sound almost like it is thin metal tapping or even sounds like electrical sparks popping. it only happens when i am in gear and driving. it is coming from somewhere from the tranny to the rear end. sometimes it goes away for a while but then sometimes it will be there all day. When i accelerate the noise increases with the acceleration. Now on to the vibrating. When i am driving on the express way above 65 mph and i let of the gas it almost sounds like i have an engine brake from a deisel on my truck. when i get on the gas again i can feel a clunk almost like there is something loose in the rear end. if anyone can help that would be greatly appreciated. The cracking/popping noise is my main concern. i have never heard that noise before on a vehicle other than electrical arching.
Thank you.
Old Oct 10, 2009 | 01:30 PM
First thing to check would be the u-joints.
Old Oct 10, 2009 | 02:34 PM
Jr_WaxDr's Avatar
Well I took the rear end cover off and I had someone shift it from drive and then into reverse and I could see the pinion gear moving up and down about an 1/8 inch either way. Could it be the bearing on the pinion gear gone bad?
