Vibration
Old Oct 3, 2009 | 01:03 PM
ivrodriguezfx4's Avatar
Vibration
guys i drive a 06 fx4 supercrew, i have been experiencing a vibration between 50mph and 65. Below that no vibration and above no vibration neither.
I replaced already the engine mounts, trasmission mounts, u-joints on both driveshafts however the u-joints are not the original ones they are universal,i dont know what to do any help guys i will apreciated
Old Oct 3, 2009 | 03:50 PM
Have you had your tires checked for balance and out of round?
Old Oct 3, 2009 | 05:43 PM
AntzFreshWhip's Avatar
^^^x2 where specificly do you feel the vibration? like in the steering wheel or the whole truck?
Old Oct 4, 2009 | 07:03 PM
Yes they are balanced it is underneth that a feel the vibration
Old Oct 4, 2009 | 07:05 PM
in the whole truck steering wheel is fine i dont know what to do.
Old Oct 4, 2009 | 07:22 PM
dam...anything beyond that is beyond me...sorry dude..
Old Oct 4, 2009 | 07:49 PM
james04's Avatar
Try having you driveshaft turned 180 degrees and reinstalled, see if the vibration lessens in any way at the same speed. Mine would "whip" at around 80-90mph (it's a one piece and it sounds like yours is a two piece?). I had it removed and rotated 180 degrees and the vibration changed completely. I then went out and bought an aftermarket driveshaft and now I have no vibration. This may not be what's causing your vibe, but may be worth a try. Good luck down there.
Old Oct 5, 2009 | 12:56 AM
They may be balanced, but are they true and round? Are you sure you don't have a bent wheel?
Old Oct 5, 2009 | 09:18 AM
thanks dude anyway apreciated your input on this.
Old Oct 5, 2009 | 09:25 AM
let see if i understand you. first of all what driveshaft both and what you mean by turnig it 180? apreciated your inputs
Old Oct 5, 2009 | 09:29 AM
well they are brand new tires and the vibration was before i put the tires but i am going to rebalance it again in other place that a friend told me i keep you guys updated what going on apreciated.
