rear diff service intervals
Old Aug 11, 2009 | 08:07 AM
aaron.b's Avatar
my service manual states the 75 140 synthetic oil in my truck's rear axle is a lifetime synthetic oil and only needs to be changed if it's submerged in water or leaking. does this oil not break down like all other lubricants? the truck is an 01 with 56000 miles and I'm just tryin to swap out all necessary fluids before its too cold out up here.
Old Aug 11, 2009 | 09:21 AM
grizzstang's Avatar
I think most people are changing it out at the 100,000 mile mark if not before.
Old Aug 11, 2009 | 12:51 PM
If you have limited slip, you should change it at least every 100k, and use friction modifier. Otherwise, the LS clutches are going to start to chatter.
Old Aug 11, 2009 | 01:53 PM
aaron.b's Avatar
Thanks guys. It is an open diff. I'll wait till I hit 100 and change it out at the same time I do the front just to make sure its good and clean.
