Clicking when breaking?????????? Help.
Old Jul 14, 2009 | 10:42 AM
efuehrin's Avatar
Question Clicking when breaking?????????? Help.
Ok I haven't had a chance to try to figure out what the problems is yet but I figured I'd ask you guy's in case anyone has ran across this before.
When I'm coming to a stop and I have the windows down I can hear a clicking sound towards the front of the truck.
It sounds like it clicks at each revolution of the tire. It only does it with the brakes on?
CV joints???
That's my first guess but it doesn't do it when I'm turning, just when I'm braking.
Ideas?
Old Jul 14, 2009 | 11:35 PM
4.2trimble's Avatar
wheel spacers.
pull the tires off and make sure they are tight, as you know mine came loose 4 or 5 times from the vibration of the mud tires. i ended up putting blue loctite on them.
id start there and see what you get, hows your brake pads? if they wear out enough they will tap.
Old Jul 15, 2009 | 10:21 AM
efuehrin's Avatar
I had not thought about that.
I'll have to check that out. Thanks for the suggestion.
Old Jul 23, 2009 | 08:25 AM
skooba's Avatar
Mine is doing kinda the same thing only it is coming from the rear also..It is an 03 4x4 with stock wheels and tires. Does it have spacers? What else could it be it is driving me nuts. It does it just when i slow down to almost a stop.
Old Jul 23, 2009 | 11:42 AM
efuehrin's Avatar
skooba, your have spacers too?
Mine does.
I have it on jacks right now in the garage, I'm going to check all the lug nuts real good before I drive it again.
Old Jul 23, 2009 | 09:32 PM
skooba's Avatar
Mine is stock so I don't know... I guess that is what i'm asking..The ticking is gettting annoying.
Old Jul 23, 2009 | 09:34 PM
skooba's Avatar
Brakes maybe... But they aren't squealing of anything.. They are the stock pads..Anybody?
Old Jul 23, 2009 | 10:32 PM
d4studmuf1n's Avatar
this may be stating the obvious but did you look for a nail or screw in the tier? it may tick all the time but you can hear it over the road noise.
Old Jul 24, 2009 | 12:29 AM
efuehrin's Avatar
^^^^^^ Good point. I doubt that's it but I'll check them over.
Old Jul 24, 2009 | 08:08 AM
skooba's Avatar
Yes, I checked for nails and rocks in the tires. I checked for sticks or anything like that also. Nothing is in the way..?? Now what?
