8.8 support 5.4L?
Old May 29, 2009 | 08:28 PM
ckyuv's Avatar
8.8 support 5.4L?
i have an 02 with the 4.6 and i ttok it into the shop today and they said it was time to replace the engine. i was looking at getting the 5.4 installed but was curious if the 8.8 would handle the larger engine or if it would be affected negatively
Old May 29, 2009 | 08:40 PM
Camarothatcould's Avatar
usually the trans takes up the abuse before the rear. Unless your manual. Wouldnt worry about the rear
Old May 29, 2009 | 08:55 PM
ckyuv's Avatar
does the 5.4 use the same tranny as the 4.6? i have replaces the transmission with a used one already and would not like to do it again!
Old May 29, 2009 | 09:07 PM
yes it should. SEARCH this forum, there are several write-ups...
EX: I swapped a 5.4 reusing everything from my 4sixxx. coils, tranny, etc
Old May 29, 2009 | 11:18 PM
Roadie's Avatar
I think the 9.75 is needed mostly for towing. If you don't do a lot of heavy towing, the 8.8 will probably do just fine.
Old May 30, 2009 | 12:27 AM
Klitch's Avatar
i aint popped mine yet with the 5.4 lightning. i'll let you know when it does. currently have 4k miles of ABUSE on that rear axle behind the lightning powerplant.
Old May 31, 2009 | 04:20 PM
ckyuv's Avatar
cool thanks for the replys, i was just checking because i had problems with it behind the 4.6 and dont know what i am getting into quite yet
Old Jul 26, 2009 | 04:21 PM
FRod's Avatar
ha thats not fair klitch yours is built! ya throw a locker or posi unit in it and the only thing u will ever have to worry about is axle shafts.
Old Jul 26, 2009 | 07:20 PM
Klitch's Avatar
i should mention i recently grenaded the 8.8
was neat lookin
