differential size
Old May 22, 2009 | 05:28 AM
Stephen87's Avatar
differential size
If i get a 9.75 rear differential would it kill my truck if I get gears for the front and rear but the front are 8.8 and not 9.75 or would it not matter just as long as they are the same ratio(IE 4.10s or 4.56s)
Old May 22, 2009 | 07:14 AM
kingfish51's Avatar
As long as they are the same ratio, it will not hurt anything. The 4x4 F150 with a 5.4 comes standard with an 8.8 reverse cut front and a 9.75 rear.
Old May 22, 2009 | 10:55 AM
4.6 Punisher's Avatar
I'm not sure what your asking but you need to get a reverse cut 8.8 for the front, and a 9.75 for the rear, both with the same ratio.
Old May 22, 2009 | 03:11 PM
Stephen87's Avatar
Ok I just thought that on the 5.4 the front was also a 9.75 inch ring gear but I guess not
Old May 26, 2009 | 08:08 PM
Roadie's Avatar
The fronts don't need to be 9.75". Think about it. The only time the front is used is when the truck is in 4 wheel drive. Then, the torque is spread over both differentials. When in 2 wheel drive, the rear takes all of the torque and therefore needs to be 9.75".
