Differential cover hardware
Old May 17, 2009 | 10:12 AM
LARIAT1's Avatar
From: INDIANA,.....USA " Where more than Corn grows in Indiana"!!!
I`m getting ready to change my differential cover 8.8 ( TA Perforamance Alum.) & I`m going to use stainless steel socket head bolts instead of the steel ones that came with it.
Using SS ok to use or should I use the regular steel ones????
Lariat#1
Old May 17, 2009 | 11:57 AM
HYPO's Avatar
I did the same when I put a TA Performance cover on my 9.75 rear last summer. It has gone through a Michigan winter with salt, etc. No problems. I know that there is the possibility of corrosion with dissimilar metals, but when I discussed the idea with a friend who has owned and run a machine shop for over 30 years, he just chuckled when I discussed the possibility. Just take it to a coin car wash and hit it with the spray maybe once a week during the winter if you live in the snow belt. It isn't a bad idea anyhow because rust is more of a problem with the steel undersides of the truck. Besides, if you ever see pitting around the bolts (doubtful), just put the powder coated bolts back in. Personally, I think this is largely a non-issue
HYPO
Old May 17, 2009 | 03:55 PM
LARIAT1's Avatar
Hypo,
You used Stainless Steel on yours???
Lariat#1
Old May 17, 2009 | 06:06 PM
HYPO's Avatar
Originally Posted by hypo
i did the same when i put a ta performance cover on my 9.75 rear last summer. It has gone through a michigan winter with salt, etc. No problems.
Hypo
yes
hypo
