axle tube leak ?
axle tube leak ?
Whats up guys. Just a couple of inches from where the axle tubes go into the center section there are what appear to welds of some sort( plug?, spot?). The one on the right is leaking. I took it to the dealer and they said there is no detectable leak at this time, which is very curious since you can visually see little drops of oil on it whenever I drive it. Has anyone else had this issue or know anything about this or could be causing it.
http://www.pirate4x4.com/forum/showt...ight=spun+tube
