Hard time going into 4WD
Old Mar 20, 2009 | 09:33 PM
mtyost's Avatar
My truck has a really hard time going into 4WD or coming out of 4WD. It is a manual transfer case. The shift lever doesn't really want to budge.
Any idea what is wrong? or how I can make it shift easier?
Specs:
1997 F150 XLT supercab, 4.6 v8, auto tranny, manual 4x4. Stock everything. 211,000 miles.
Old Mar 23, 2009 | 11:49 PM
warhammer44's Avatar
Alot of times they are pretty tough may just be wear and tear, are u talking about 4 hi or 4 lo ?
Old Mar 23, 2009 | 11:59 PM
minimonster17's Avatar
unbolt and inspect the physical linkage for corrosion/missing chunks, etc. that would be a good place to start.
Old Mar 30, 2009 | 01:11 AM
bigchief2472000's Avatar
a couple months after i got my truck i bottomed out on a curb and bent the crossmember a little bit. i had never used the 4wd before then but when i did start using it mine was always hard to shift, i never thought anything of it just figured thats how it was made. but then after having a new tranny installed a couple years down the road and having some vibration issues i ended up putting a new crossmember under there and it didnt fix the vibration but it did make the 4wd shift smooth. i guess it had put the transfer case in a bind.
