just got yukon 4.56 gears
Old Feb 25, 2009 | 05:26 PM
05extcabflare's Avatar
well I got my income tax check back and purchased gears. Yukon gears was 400.00 rear, 350.00 install kit, front 265.00,225.00 install kit, 400 install. So it came to 1718.00 Is that a fair price?
Old Feb 25, 2009 | 07:01 PM
_cashel's Avatar
Sounds a little high. The shops I called up were quoting me anywhere from 1300 - 1500. I ended up getting a friend to do it for the price of gears + a little extra, spent about $650 to do my front and rear.
Old Feb 25, 2009 | 07:44 PM
noblem's Avatar
A local shop charged me $1100, was the cheapest I could find in town, but I had to pull out the front differential and the rear axle, took just the differential and the axle to the shop then they installed the gears and I had to put them back on the truck. Otherwise I was looking at hundreds of dollars more per axle. I dont know how many shops will let you do that, but that could be a alternative to save a few hundred
Old Feb 25, 2009 | 08:37 PM
Fifty150's Avatar
FREE SHIPPING ON ALL ORDERS
Motive Performance Plus 4.56 Gears for 8.8" Front
Item #: T60009
Manufacturer Info: Motive F888456IFS
Market Price: $231.99 - You Save 9% ($22.00)
Our price: $209.99
Availability: Usually ships the next business day.
Product DescriptionTo get the best performance gear ratio out of your Ford Truck, you have to install Motive Performance Plus Gears. Motive Performance Plus Gears are crafted from extra strong race quality alloy and should last a lifetime. Motive does not have a bad reputation for “gear whine” so you can still enjoy your ride, while having the ratio of power you enjoy.
It is highly recommended that you get a Master Bearing Kit or just an Installation Kit if you are installing on a truck with over 60k miles. Shop installation costs will vary.
Specifications
Fitment: 8.8" Ford Front Year Range: F150: 1997+ Gear Ratio: 4.56
Motive Bearing Kit for 8.8" Rear (97+)
Item #: 21201
Manufacturer Info: Motive R8.8RMK
Market Price: $82.99 - You Save 10% ($8.00)
Our price: $74.99
Product DescriptionThe Motive Master Bearing kit is highly recommended gear installation on any vehicle with over 60k miles. Think of this kit as a cheap insurance policy on both your gears, and your Ford Truck. This kit includes everything that you need for a gear installation.
Note: This kit is compatible with 1997+ Ford F-150s
Kit Includes:
Front & Rear Pinion Bearing
Pinion Seal
Carrier Bearings
Carrier Shims
Differential Bearings
Crush Sleeve
Pinion Nut
Cover Gasket
Ring Gear Bolts
Brush
Gear Marking Compound
Loctite
Ford Truck Motive Performance Plus 4.56 Gears (9.75" Rear)
Item #: T30003
Manufacturer Info: Motive Gears F9.75-456
Market Price: $245.99 - You Save 11% ($26.00)
Our price: $219.99
Specifications
Fitment: 9.75" Ford Rear Year Range: F150: 1997+ Gear Ratio: 4.56
Ford Truck Motive Master Bearing Kit 9.75" (Mid 99+)
Item #: T30012
Manufacturer Info: Motive R9.75FRLMK
Our price: $219.99
Note: This kit is compatible with Mid-year 1999+ Ford F-150s
Kit Includes:
Pinion Seal
Carrier Bearings
Carrier Shims
Crush Sleeve
Pinion Nut
Cover Gasket
Ring Gear Bolts
Brush
Loctite
Old Feb 25, 2009 | 08:43 PM
Fifty150's Avatar
Labor is about right. But your parts cost is way high.
Next time, check around before you buy. It's too late now. You've already bought all this stuff.
Old Feb 25, 2009 | 11:50 PM
_cashel's Avatar
I imagine just about any shop would. I would definitely drop the diffs myself to save some money. They're both really really easy to drop and it just takes a few bolts to undo.
Old Feb 26, 2009 | 10:02 AM
Mikehunts2's Avatar
Just wondering
What does installing 4.56 gears do for your truck? Does it get better fuel or towing? What size gears were you replacing?
Thx
