Rtv?
Old Feb 23, 2009 | 10:33 PM
wreedKR's Avatar
Rtv?
What color or type of RTV does one use on the rear end diff cover?
Old Feb 24, 2009 | 03:40 AM
bigbronc's Avatar
I use the black, but we got some gray that once dry won't leak, and is a pain to get off if it has to come back apart later. Just don't get the cheap stuff, and you'll be ok.
Old Feb 24, 2009 | 11:40 PM
Fifty150's Avatar
Why are you using RTV? I thought you had a Mag-Hytec.
Old Feb 25, 2009 | 03:56 AM
86notch's Avatar
I use the red on just about everything with out any problems.
Old Feb 25, 2009 | 08:54 AM
wreedKR's Avatar
i have more than one vehicle
What is the difference in the colors?
Old Feb 28, 2009 | 12:18 PM
wreedKR's Avatar
Old Feb 28, 2009 | 05:22 PM
bigbronc's Avatar
Different applications. Black and gray are multi-use, red is high temp, etc. If you are sealing a rear end, use the black. Doesn't look as crappy when seen from the rear as the red does. I used the black on everything at the shop, until we started using the gray. The gray needs time to "set", before any fluids go in, but it SEALS!!!!
Old Mar 1, 2009 | 03:50 AM
BlueOvalFitter's Avatar
Thumbs up
Use a gasket!
Old Mar 1, 2009 | 10:44 PM
Fifty150's Avatar
I see gray used a lot. When cured properly, it is a great seal.
Old Mar 2, 2009 | 04:34 AM
bigbronc's Avatar
I used to use gaskets on my 9 inch in my old truck. Everytime I did, it would leak. One time, I had it out and they ran out of the gasket at my parts store, so I put RTV on it. Guess what, it never leaked. I haven't put a gasket on one since (around 1991). The only time RTV leaks, is if it isn't properly applied, or oil is put in too soon.
Old Mar 2, 2009 | 05:27 AM
Cool
Use a gasket!
Old Mar 3, 2009 | 03:00 AM
Fifty150's Avatar
Is gasket vs RTV turning into the next motor oil debate?
Old Apr 16, 2009 | 11:23 PM
wreedKR's Avatar
Is Permatex found at Oreilly good?
Old Apr 20, 2009 | 09:28 PM
PhqChevys's Avatar
That's what I've always used...never had a problem with it
Old Apr 20, 2009 | 10:17 PM
Permatex is Permatex - it's just there are several different types.
