limited slip
Old Feb 21, 2009 | 03:33 PM
geerusso's Avatar
Exclamation limited slip
2002 Ford F150
69,000
I had the back of my truck up checking out the rear bearings, the truck was in neutral and i noticed the tires did not spin easily. I have limited slip and I noticed when spinning the passenger side the other side would move along with it , but when I would spin the driver side nothing would happen to the other side. Is this normal for limited slip or does this require some looking into.
Old Feb 21, 2009 | 11:54 PM
StuartTX's Avatar
Was the driveshaft disconnected or the t-case in neutral?
If you spin one wheel with the trans./t-case in neutral the other wheel should turn in the opposite direction.
