rear end?
Old Aug 24, 2008 | 08:26 PM
f150fella08's Avatar
rear end?
ok guys, i know nothing about rear ends, but could this be right 3.08 gears on a 2002 4.6 v8? 3.06 seems WAY to small, anyways guys i appreciate the help
Old Aug 24, 2008 | 09:35 PM
minimonster17's Avatar
please post your axle code, and we will tell you. i am not familiar w/ the gearing offerings on a 4x2 4.6, but i imagine it would be at least a 3.30...
Old Aug 24, 2008 | 09:49 PM
i figured 3.08 was rather small, and since its dark out ill have to get that for you tomorrow
Old Aug 25, 2008 | 04:05 PM
keep in mind, it can be found in the driver's side door jamb sticker as well.
Old Aug 25, 2008 | 05:15 PM
where at? i saw it said axle 19 what do i need to look for on the sticker
Old Aug 25, 2008 | 05:27 PM
The first digit tells the chassis weight & type of diff; the 2nd tells the ratio; if there's a 3rd digit (4WD only), it means the front diff is limited slip. In the first digit, 1 is the code for most 1/2-ton open diffs; 2 can be 1/2- or 3/4-ton open; H is a 1/2-ton limited slip. (Any letter in the first digit means L/S.) In the 2nd digit, 2 = 2.73; 3 = 5.13; 4 = 3.54; 5 = 4.10; 6 = 3.73; 7 = 3.31; 8 = 3.08 (or sometimes 4.88); 9 = 3.55.
I think a 19 would be an open, 3.55.
Old Aug 25, 2008 | 05:34 PM
ohhh ok i understand now!!! thanks bluejay!
Old Aug 25, 2008 | 05:38 PM
Bindernut's Avatar
Use the listing that Bluejay posted, that's got the gearing options covered pretty good for 150s and LD250s.
That said, when my folks got their 98 the dealer screwed up the order sheet and it came with 3.08 gears. Dad refused the truck and the dealer reordered so I don't know whatever happened to it but someone sure got one doggy 4x4! Yep, there's at least one '98 F150 4x4, 5.4/auto/3.08 running around somewhere in South Dakota.
Old Aug 25, 2008 | 05:47 PM
I found the one I was looking for, it's a little cleaner list.
19 — 3.55 non-limited slip — F-150
25 — 4.10 non-limited slip — F-150
26 — 3.73 non-limited slip — F-150/Mark LT
27 — 3.31 non-limited slip — F-150
B5 — 4.10 limited slip — F-150
B6 — 3.73 limited slip — F-150/Mark LT
H9 — 3.55 limited slip — F-150
18 = 3.08 non-limited slip — F-150
Old Aug 25, 2008 | 05:54 PM
thanks alot bluejay only thing i hate is non-limited slip lol
