stiff steering
Old Aug 11, 2008 | 02:59 PM
dvss's Avatar
stiff steering
04 f-150 fx4,when making a turn onto a side street either right or left, sometimes the steering becomes stiff and u pretty much have to force the wheels straight again, when i first happen i thought i had a flat front tire. all trie pressures a good, and my power steering pump makes no whining noise
Old Aug 11, 2008 | 03:27 PM
Whiteghost's Avatar
Check the Tie Rod Ends (Inner and outer on each side)
Check the Idler Arm
Check the Pitman Arm
And grease any fittings you find.
That's what I would start with.
My quess is the Idler arm or Pitman arm are causing your trouble.
