Gear questions
Old Jul 30, 2008 | 02:35 AM
dkgreyf150's Avatar
Gear questions
i have a 2006 fx4 6'' lift 35's 17' want 37 but have stock gears and i want a little bit more quickness out of it i have a hypertech and an airaid intake but i dont really know anything about gears so somebody help me out and explain them a little, tell me what r the best 4.56 or 4.88 ,where to find them ,and how much
Old Jul 30, 2008 | 08:32 AM
05_sprcrw's Avatar
If you are going with anything bigger then 35's then go with the 4.88's.
The two links below have a ton of info in them. The first one covers a lot of the basics, and the second one is a link on how to do it yourself.
1. https://www.f150online.com/forums/ot...supercrew.html
2. https://www.f150online.com/forums/ot...p-rev-1-a.html
Old Jul 30, 2008 | 03:43 PM
dkgreyf150's Avatar
ok thanks so do i have to change the front and the back or just the back and what is the 8.8 and 9.75 and what is mine
Old Jul 30, 2008 | 03:46 PM
dkgreyf150's Avatar
so im lookin at around 600 plus installation
Old Jul 31, 2008 | 08:42 AM
05_sprcrw's Avatar
Yes if you are changing you will have to do them both. You can do the rear first and drive around for a while on it if you are unsure which one you want to go with. Just make sure you don't use 4 wheel drive if you use it say good by to some very expensive parts. And a good overall estimate for everything done and said is around 1400-1500. Not cheap but it will save a ton of headaches down the road.
