rear dif size
rear dif size
I was looking for a bigger rear differential for my lightining swap and I have been told to get a 9.75 diff. however in looking for one I found one off of a 2000 f150 that is 10.25" ring gear and I was wandering if I could use that one on my truck also when i get it would I have to change my front 8.8 to a 10.25 and also since it is a 3.73 I would have to change my front to a 3.73 reverse cut right.
You would not have to change your front to a 10.25 dif. it can stay at 8.8, but if your front end is not geared the same as the rear that is where you will run into problems. So yes you will have to switch to 3.73's up front if that is what the rear is. And yes you do need a reverse cut gear for the front.
I would go that route to personally. But if you go with the 9.75 you will only have to re-gear the front dif to match the rear and you will be just fine.
some early 9.75's came stock w/ drums, while others came w/ discs. it depends on the individual axle you purchase. if possible, i would convert to discs in your situation, but there is some extra work involved. ssj4shane did a swap to a 9.75 w/ discs, i think.
