noise from rearend
Old Mar 20, 2008 | 12:48 PM
FL4X4's Avatar
noise from rearend
I've had my truck for a while now its a 04 f150 heritage xl 4x4 with a 4.6l. I noticed that around 40-45 theres a loud whining noise coming from the rear. Its weird because I only hear it at about 40mph then it gets louder until 45 then any thing faster or slower it stops. And also I only hear it while I press the gas.
Any one have an idea of what this could be? thx
Old Mar 20, 2008 | 05:34 PM
BlueOvalFitter's Avatar
Exclamation
Sounds like the pinion bearing/bearings are going out.My 97 did the same thing and it was the pinion bearings and one of the carrier bearings.
Old Mar 20, 2008 | 06:15 PM
mrkwns's Avatar
+1 , mine too.
Old Mar 20, 2008 | 07:29 PM
FL4X4's Avatar
thx for the info, how much did that cost you to fix?
Old Mar 21, 2008 | 01:46 AM
Thumbs up
Well,mine was an open 8.8 differential.Total rebuild,from wheel to wheel,excluding axles,was $800.It included;US Gears,carrier,all bearings and seals,spider gears,and after 500 miles the initial gear break-in lube change.
Old Mar 21, 2008 | 01:49 AM
Thumbs up
BTW,what part of Florida are you in? This is where I had my work done;
http://www.agearworks.com/
Old Mar 21, 2008 | 12:24 PM
FL4X4's Avatar
thx a lot, i live in Tampa area
Old Mar 21, 2008 | 04:56 PM
Thumbs up
Well then,Alans Gears is in Clearwater.They will do an excellent gear install job if you take it there!
Old Mar 24, 2008 | 10:00 AM
mrkwns's Avatar
Mine was warranty work. Happened at 7000 miles. 30000 since though and has been fine.
