lockers
Old Mar 12, 2008 | 01:37 PM
Rkienzle's Avatar
lockers
I was wondering if anyone has installed a front and rear locker on there 04-07 f150, and what is a good one to go with. I don't want a full time one as I use my truck as a daily driver. I know the Jeep Rubicon has some that lock when you flip the switch this is something that I am interested in
Old Mar 12, 2008 | 04:32 PM
MercedesTech's Avatar
Ya, there are guys running lockers on this site, but just so you know, your in the "comment and suggestion" section, generally saved for comments and suggestions *for the site itself*. You will have much better luck posting in the "Other Powertrain" section, or even the off-road section.
tnsilvfx4 I believe is the name, is running a front selectable locker.
Check out Eaton Selectable (electric)
Auburn ECTED (electric)
ARB (air operated)
Or OX Lockers (cable operated)
Old Mar 16, 2008 | 01:33 PM
BuRDeN04FX4's Avatar
I am also intersted in a switchable rear only most likely electric im woundering how hard it is to do the install thanks for any help also does anyone have any experance with any electric once thanks
Old Mar 17, 2008 | 02:35 AM
You also need to post in the correct section.
Old Mar 19, 2008 | 02:07 PM
tnsilverfx4's Avatar
Ive got a selectable Auburn ECTED in front.
Both mercedes and I have plans for a detroit locker in rear
Old Mar 19, 2008 | 11:24 PM
Y wouldnt u put on in the rear first just curious how was it install i do a pretty good amount of off roaading but also drive 60 miles every day for work so keeping it streetable is very important thanks
Old Mar 20, 2008 | 10:35 AM
My factory LS was fine at the time of install. When the clutches go I'll install the detroit. I can get a good deal on install for the locker so im not worried about it. At the time, I couldnt afford the extra $$ for a detroit and install.
You will be streetable with a selectable up front. Just leave it off until you need it.
btw, i think the only rear locker options are an OX if you have an 8.8 rear, and the detroit for either 8.8 or 9.75
Old Mar 20, 2008 | 11:15 AM
Also, a locker up front has more benefits when off-road. With a truck, we have NO weight sitting over our rear axle, but sure do have a ton up front. More weight up front = more traction. Adding the "traction aid" up front can really help you pull through some nasty stuff. Just my opinion.
driving 60 miles a day ?? Damn buddy, I'd suggest looking into a little ricer or something. Maybe a bike. Save some gas + cash. I drive 70+ miles a day for work, and would no way want my truck to be a daily driver. Buy yourself a little foreign job with great MPG's .... then beef up that truck ! Or go with selectables. More expensive, but you won't need to drive around "locked up" all the time.
Old Apr 16, 2008 | 12:27 AM
OrdnanceCorps's Avatar
... seriously stab yourself in the face!!! Wrong section.. however.. has been moved to correct forum
Old Apr 16, 2008 | 01:09 AM
Delta17's Avatar
i've got probably a stupid question but i just want to check with you guys,
If I were to purchase a detroit locker, would i have to also pay to have the clutch packs replaced too. I know my clutch packs are turning to crap, and if I could just pay for a locker and then pay for install, that would be fine with me.
would the clutch packs have to be messed with if i bought a locker?
thanks,
John
Old Apr 16, 2008 | 01:17 AM
Klitch's Avatar
the LS carrier with the clutch packs gets replaced via the detroit locker.
