Squeak from the rear?
Old Feb 22, 2008 | 07:40 PM
91SuperCrew's Avatar
Only when I am backing up at a slow speed is there a squeak coming from the middle of the truck to the back. I am thinking u-joint but it does not do it while going forward at the same speed. Any other ideas?
Old Feb 23, 2008 | 12:02 AM
02SC4x4's Avatar
u joint.
i had the same thing on my 02, and i thought the same thing, y does it only do it in reverse? im sure if you could get the shaft spinning at 75mph in reverse for a couple of hours it wouldnt do it.
you probably have the factory sealed u joints. put a couple of lubable ones on there and ur good to go (as long as u lube em).
i might suggest getting the shaft balanced too while you at it. the squeaking is actually the joint seizing and releasing.
Old Feb 25, 2008 | 12:41 PM
chumFX4's Avatar
Try this....
Sorry, couldn't resist
Old Mar 3, 2008 | 09:12 PM
I check the ujoints and there is a little plat but not alot...I am just confused why it only does it in reverse?????
Old Mar 4, 2008 | 03:12 AM
A little play is too much.
