4X4 light
Old Feb 16, 2008 | 05:08 PM
mike y's Avatar
4X4 light
I have a 05 f150 and the 4x4 high light in the dash doesn't light up, sometimes it will flash 1 time but nothing else. The 4x4 low light works fine.The 4 wheel drive works fine in high and low just this problem with the light. This is electric shift any idea's? Thanks Mike
Old Feb 17, 2008 | 02:50 AM
sean_somer's Avatar
bulb out? going out? loose connection?
Old Feb 17, 2008 | 08:08 AM
mike y's Avatar
Not a bulb problem I have checked that
Old Feb 18, 2008 | 08:57 AM
sean_somer's Avatar
hmmm, well if the 4x4 is working fine then i wouldt think it has anything to do with the transfer case itself. could be posistion sensor but if it engages correctly its ok. you would know if theres a problem with the sensor because it wouldnt know its in 4x4 & continue trying to shift.
it could be the gem not continuisly sending power to the bulb, a short in the connection, or a loose connection.
you could try this thread in the transmission section
it would probly get alot more replies
