In need of advice.
Old Feb 16, 2008 | 12:21 PM
braupe's Avatar
In need of advice.
Hey Guys I need a few pointers. I am looking to swap out me open diff for a trac-lok and changing gears on my 99 f150 4.6 auto. I think I either have 3.08's, or 3.27's in a 8.8.
The question is do I swap to 3.55, 3.73, or 4.10's? I would like to keep the revs under 2500 rpm at 70 mph. I do mostly city driving, but do occationally hit the hwy.
Thanks in advance,
-braupe
Old Feb 16, 2008 | 01:23 PM
What gears do you have? Check the axle code on the door sticker. What tire size are you running?
Old Feb 16, 2008 | 01:57 PM
braupe's Avatar
Axle code is 19.
Tire size is 255/70/16
Old Feb 16, 2008 | 05:52 PM
mbogosia's Avatar
Registered User
I just went from 3.55's and 33's to 4.10's and 33's and didn't notice a huge difference. If I was you I would go with the 4.10's. With 33's I am at 2200 rpm's at 70mph.
Old Feb 17, 2008 | 12:33 PM
braupe's Avatar
Good advise, thanks. At the least I will go with 4.10's. Should I consider 4.30's?
Old Feb 17, 2008 | 01:22 PM
You are running stock tires, which I think are around 29". You have 3.55's.
RPM's at 70 in OD are the following:
3.55: 2015
3.73: 2117
4.10: 2327
4.30: 2441
Old Feb 18, 2008 | 03:55 AM
braupe's Avatar
3.55: 2015
3.73: 2117
4.10: 2327
4.30: 2441
Wow that is great info. Thank you so much.
I think I will go with 4.10's.... its not a race truck, im just wanting a little more umph.
Old Feb 18, 2008 | 07:54 PM
rmadison's Avatar
i wouldnt go over 3.73 if i was not gonna go bigger than those stock tires. 4.10 and 33 would even put you higher than your stock gearing. maybe 4.10 and 31
