Rear end code
Old Feb 9, 2008 | 12:04 PM
munoxide's Avatar
Rear end code
I have a rear end code 27 on a 01 f150 screw. I looked at the list but only found the code under the f250. Anyone know what rear end code this is?
Old Feb 9, 2008 | 02:10 PM
3.31 open.
Old Feb 9, 2008 | 02:15 PM
munoxide's Avatar
Originally Posted by glc
3.31 open.
Thanks, but where did you get that info from?
Old Feb 9, 2008 | 02:27 PM
02SCSB5.4L4x4's Avatar
i've got the 27 code in my 02 F150 that i bought last month as well and ran into the same thing, i could only find the 27 code listed under the F250 no matter where i looked. however, luckily i found the original window sticker with the owner's manual and it listed the rearend diff gears as 3.31 ratio and an open differential
Jason
2002 F150 XLT 4x4
5.4L
Single Cab
Short Box
Old Feb 9, 2008 | 02:28 PM
munoxide's Avatar
Jason
2002 F150 XLT 4x4
5.4L
Single Cab
Short Box
Thanks for the info. Any idea onthe max trailer weight for this rear end with a 5.4? I cant find it on the chart.
Old Feb 9, 2008 | 05:19 PM
The charts I can find only go back to 2002, and the 2002 Screw didn't offer 3.31's. With 3.55's, the 2002's are:
5.4 4x2 - 8000
5.4 4x4 - 7100 or 7600 depending on wheels/tires
Old Feb 9, 2008 | 05:22 PM
I didn't even know they put 3.31's on the F250... that thing must DOG.
Old Feb 9, 2008 | 05:36 PM
kingfish51's Avatar
Page 177 of your owners manual. If you do not have one, you can download one from the link below in PDF format.
http://www.motorcraftservice.com/vdi...&VEHICLE=F-150
Old Feb 9, 2008 | 10:18 PM
munoxide's Avatar
The manual only specifies for 3.55 axle.
Old Feb 9, 2008 | 10:19 PM
munoxide's Avatar
5.4 4x2 - 8000
Sorry, i meant scab, not screw.
Old Feb 10, 2008 | 07:15 AM
kingfish51's Avatar
Page 177
SuperCab /Super Crew 4x4 w/automatic transmission
eng/rear GCWR kg(lbs) trailer weight kg(lbs)
4.6L 3.31/40.6 (16) 4 763 (10 500) 2 540 (5 600)
4.6L 3.55/40.6 (16) 5 216 (11 500) 2 994 (6 600)/2 857 (6 300)
4.6L 3.55/43.2 (17) 4 990 (11 000) 2 767 (6 100)/2 630 (5 800)
5.4L 3.31/40.6 (16) 5 443 (12 000) 3 130 (6 900)
5.4L 3.55/40.6 (16) 5 897 (13 000) 3 583 (7 900)/3 492 (7 700)
5.4L 3.55/43.2 (17) 5 670 (12 500) 3 357 (7 400)/3 265 (7 200)
5.4L 3.73/40.6 (16) 6 124 (13 500) 3 765 (8 300)
Old Feb 10, 2008 | 10:56 AM
munoxide's Avatar
Page 177
Thanks.
