transfer case fluid change
Old Dec 31, 2007 | 05:56 PM
KDracing's Avatar
truck is 2000 F150 5.4 auto
thinking of changing my transfer case fluid, how hard is this to do? think i found the drain plug, couldn't locate the fill plug. does the tcase call for gear case oil or ATF?
anyone have a nice step by step out there? tried searching for one but found nothing.
Thanks KDRACING
Old Dec 31, 2007 | 10:18 PM
jbrew's Avatar
A Haynes or Chiltons manual would be a good investment - Fill plug is above the drain plug . Takes two quarts of ATF Fluid. It better to use a fluid injecting syringe to change , otherwise it's a PITA.
Old Jan 1, 2008 | 11:56 AM
KDracing's Avatar
thanks for the info, i also just found the other thread in the transmissions section. i guess i should have put this there.
