trans case or u-joint noise
Old Dec 29, 2007 | 09:10 PM
flatlander61's Avatar
Question trans case or u-joint noise
I bought this 93 f150 XLT in Novemeber, The few times I have engaged the 4x4 a noise comes from the front passenger sider. At first it was a loud rubbing sound, the other day it evolved into a banging noise lots of vibration.
1 mech says its a u-joint another says its the transfer case.
Is there any way to tell before spending lots of cash?
thanks to anyone who helps.
Old Dec 30, 2007 | 05:00 PM
Also noise stops as soon as hubs (manual) are unlocked.
Old Jan 1, 2008 | 09:28 PM
Drobinson6969's Avatar
Its deff your u joints. replacin u joints is not very hard and is pretty cheap. let me kno if that helps.
Old Jan 5, 2008 | 01:10 PM
Thanks. It was the u-joint, but whats with the clicking noise on these when in 4x4.. Friend of mine also has it on his 02?
Old Jan 5, 2008 | 01:16 PM
kingfish51's Avatar
Clicking can be a u-joint or if you have the manual hubs unlocked and put into 4x4, you can get a clicking noise. Not good for the hubs. More likely a u-joint. Don't forget, there are 8 of them on th 4x4 version.
Old Jan 5, 2008 | 01:23 PM
I already had the bad u-joint replaced.Mech says the others are solid.
Clicking only occurs when the hubs are locked and 4hi is engaged. sound continues after going to 2hi until I stop and reverse a few feet.
thanks for your help.
Old Jan 5, 2008 | 01:35 PM
chris dornbusch's Avatar
try the axel look at the boots and stuff for metal shavings ,you mill know as soon as you look,if the boot is bad then the axal is most likely the problem
Old Jan 12, 2008 | 08:49 PM
well, the boots are ok..no tears or cracks and clamps are tight.
