Best Gear Ratio
Old Oct 8, 2007 | 02:22 PM
white05stx's Avatar
Best Gear Ratio
I have a 2005 F-150 STX single cab with the 4.2L in it. About two months ago i put a fabtech 6" kit on it and some 35's. I need to swap out my gears but i dont know which ones to get. I might eventually add a 3" body lift and get some 37's so might plan ahead for that. Any help would be great!
Old Oct 8, 2007 | 03:00 PM
4.56's or 4.88's.
Old Oct 8, 2007 | 03:10 PM
4.10s will be A.O.K too.
Old Oct 8, 2007 | 03:54 PM
4.10's may not be low enough with 37's.
Old Oct 8, 2007 | 05:19 PM
jiggle's Avatar
I agree. If I had a 4.2L I would run no higher than 4.56s with 35s, and definitely not with 37s. I'd say 4.88s.
Old Oct 8, 2007 | 08:12 PM
TechMike's Avatar
Auto or 5-speed? If it's an auto, 4.56's would do the trick but you'd better watch those tranny temps. Installing a tranny cooler would extend the life of the transmission now having to turn those huge tires.
Old Oct 8, 2007 | 08:39 PM
True. 4.10's would be decent for 35's while being modest on the gas.
Old Oct 9, 2007 | 03:21 PM
white05stx's Avatar
how much would a tranny cooler run me?
Old Oct 9, 2007 | 03:38 PM
jiggle's Avatar
You can get a pretty nice one on Ebay for $60 if you spend a little time looking.
Old Oct 9, 2007 | 08:45 PM
Cuisi's Avatar
You can easily determine the closest gear that will give you the same final drive ratio as stock by using a simple formula;
new tire diameter divided by original tire diameter times current gear ratio.
example
35/32(=1.09375)*3.73=4.0796
This tells you that you would need a 4.08:1 gear ratio to keep the same final drive ratio you had on your stock tires. Obviously they don't make that ratio, but a 4.10:1 is pretty damn close.
Use it as a guide, if you want a lil more grunt then go up to the next ratio.
Old Oct 10, 2007 | 10:28 AM
jiggle's Avatar
Was his stock tire size really 32s?
Old Oct 10, 2007 | 02:31 PM
Hash278's Avatar
I guess if you know your getting the 37's for sure wait for the 4.88s otherwise go with 4.56's. Pat has 4.56's with his 38's so I guess if you decide later to go bigger you'll at least be geared
Old Oct 15, 2007 | 03:25 PM
Cuisi's Avatar
No idea, it was just an example. Obviously you should put your own numbers in the right spots.
