vibration between 35-45 mph
Old Sep 28, 2007 | 09:22 AM
parkbuilder's Avatar
lately i've been having a pretty steady vibration in my 97 150 xlt 4x4 (auto transmission, 4.6 engine) it only happens when i'm driving keeping a constant speed anywhere between 35 to 45 mph. once i get to a speed higher, it goes away. also, it feels like there is a pretty good jolt when it shifts up (only at certain times) anyone have any clue on what it could be? this is my first time posting on here, but i have been searching for this problem for over 2 months now on here and have come up empty. replaced spark plugs and wires, tie rod ends, rear u-joint, all things that i found on here that may have been the problem, but none have helped. anyone think of anything else it could be?
Old Sep 28, 2007 | 11:54 AM
Tire balance/out of round?
Old Sep 28, 2007 | 03:07 PM
tires are all in balance
Old Sep 28, 2007 | 03:38 PM
ianwen's Avatar
possibly check the driveshaft for a missing weight, or put of balance?
just an idea.. most likely wrong, but its a shot
Jon
Old Sep 28, 2007 | 08:45 PM
ill check the drive shaft thing out
does anyone think it is something in the rear end ? transmission? or are they all something that i can go ahead and rule out? i just want to see if anyone else out there has had any similar problems and what it was to fix it.. its been doing this for over 3 months now and any place i've taken it to claims they don't feel it happening
Old Sep 28, 2007 | 08:53 PM
Klitch's Avatar
heres my most annoying experience. truck would bounce at around 45 mph, so bad it was visible in my mirror watching the bed. so i thought it was simple as rotating the tires to see if its moved. nothing changed, went to rotate again and the right front was stuck to the hub. i gave it a kick figuring it'll jar it off for me, except i noticed the tire shook like the tie rods were going. chased it down to be the idler arm mounting bolts were loose.
