Unidentified vibration
Old Aug 16, 2007 | 06:38 PM
Barry in CO's Avatar
I drive a 2004 F150XLT, 4wd, auto trans, electronic 4wd.
Sometimes on a hot day, after the truck has been parked for hours, I'll be driving along, 30-40 miles an hr, and the truck will start shaking, like a front end vibration. I've checked the lugnuts, the tires are balanced, letting off the gas doesn't change the vibration, slipping the trans into neutral doesn't stop it either.
When I apply the brake, the shaking is more pronounced, and when I release, it returns to the previous level of shaking.
I pull over and stop, and when I take off again, the problem has cleared.
The last time it happened, I switched to 4wd. It took a couple of minutes before I could get it back to 2wd.
I suspect a faulty 4wd solenoid or similar problem.
The dealer (Lakewood Ford, Lakewood CO) can't find any problem. You know the drill- when the mechanic test drives the truck, it drives just fine.
Does anyone have any ideas? Anyone heard of this problem before?
All replies are welcome.
Thanks,
Barry
