Gears
Why can't you pull the boat out of the water? Tires spinning or the truck just doesn't have enough *****?
I think that regearing is something that everybody should look into. The benefits from it are amazing.
Or: buy a smaller boat.
There is no power there, and i burn the clutch. I have been told that the clutch is still ok. Also in four-wheel-drive there is no power either. I was on the beach, and went up a small sand pile and the truck bouged down. I put in the clutch, so the truck stoped. When i went to go again, the tires wouldnt move, and the clutch just spun.
My friend is having the same problem with a Nissan after putting bigger tires in it. Do you have a 4.2L?
There's obviously something wrong, and regearing could very well be solution. However, gears and labor can get pretty expensive, especially on a 4wd. You'd be looking at $1200 minimum. You can get it cheaper if you really shop around. I was able to find some really good deals on gears and had my truck regeared for $1050. But I spent a couple months looking for good deals.
If I were you, I would put a little money into diagnostics to figure out what the problem is before dumping a grand into gears.
No, I have the 4.6L. My little brother is real into cars, and is going to school for automotive, he has already regeared a couple trucks, so I really only need to buy the parts. Do you still think that I should do the diagnostics to it? What would be your recomendation for the new gears if that is what I do. I currently have 285/75R16 on it, and I would like to put 35's on it eventualy.
I agree with 4.56s. If you do a lot of highway driving then you should wait until you are getting your 35s to regear. I have 4.56s and I ran my 33s (same size as your tires) for a few months until I needed new tires. It was great around town , but on the highway it really sucked up gas.
I do still think you should look more into the problem though. I have the same truck, engine, drivetrain (except I have an auto tranny) and (had) the same size tires as you, and I never had any problems like that. With my 33s and stock gears my truck was a dog, but in 4LO it still pulled pretty well.
But if you're going to 35s, you should definitely regear. Your truck won't move if you don't.
