How much should it cost to replace the front bearings?
Old Jul 27, 2007 | 11:39 AM
A1ENGINEER's Avatar
I have an 2001 F150 supercrew. The dealer wants $700 to replace both front wheel bearings. Is this a fair deal? Should I have him replace anything else while he has it apart? 116K miles.
Old Jul 27, 2007 | 11:43 AM
WOW! I would suggest finding a small local shop. Way too high in my opinion. As far as replacing other stuff, it just depends on the condition of your rotors and brake pads while you have them exposed.
Old Jul 27, 2007 | 02:35 PM
andrewc_11890's Avatar
bearings online are like 50-75 bucks, i dont think there is that much labor to charge that much
Old Jul 27, 2007 | 09:19 PM
F151's Avatar
There is a reason the Chinese bearings are cheaper, but $700 is a little tall...
Old Jul 27, 2007 | 09:22 PM
jiggle's Avatar
Is your truck 4x4? If so then the bearings themsleves cannot be replaced, but you have to replace the entire hub assembly. They run around $260 a piece.
Old Jul 28, 2007 | 03:29 PM
Klitch's Avatar
i got ford bearings for 220 each. my ford bearings lasted the truck 175k with a lift for the later 40~ish. not bad for going back with a ford replacement part. oh and napa / schucks were about $80 more than ford!
did install myself.
