4.10 gear name brands
Old Jul 21, 2007 | 10:54 PM
CDB03STX's Avatar
Gonna put 4.10 gears in my truck for more low-end. Who makes a good gear or can I just get one from Summit, Jegs, EBAY?
Thanks, Corey
Old Jul 21, 2007 | 11:06 PM
Lumadar's Avatar
Ford Racing has some, Richmond makes them I believe. That's what I went with.
Old Jul 21, 2007 | 11:19 PM
I went with Motive 4.10's...
Old Jul 21, 2007 | 11:33 PM
crash_lucky13's Avatar
superior, richmond, ford racing, motive, genuine....
what rear end do you have? i MAY be able to help you out.
Old Jul 22, 2007 | 04:50 PM
CDB03STX's Avatar
I would assume an 8.8.....Factory rear-end. I didn't know there were different ones for the newer models. What is diiferent about them.
Old Jul 22, 2007 | 05:12 PM
built54's Avatar
I have the 9.75 with ford racing 4.10's
Old Jul 22, 2007 | 07:09 PM
i have the 9.75 with Richmond 4.10'S.......
Old Jul 23, 2007 | 03:25 PM
CDB03STX's Avatar
I'm glad I asked. How do I know which rear-end I have? Is it by year, truck style.....Something I can see visually?
Thanks...CDB
Old Jul 23, 2007 | 03:56 PM
crawl up under the rear of your truck and look at your differential. normall there is 2 tags on it. it gives the dimensions on the tags....
i would say you PROBABLY have a 9.75, but i can't be positive on it.
Old Jul 23, 2007 | 04:33 PM
CDB03STX's Avatar
OK. Looks like an 8.8. Tag reads 3L55 88 (then something else).
I know my gears are 3.55 LS...is the 88 the size? Didn't see a dot.
Old Jul 24, 2007 | 11:34 PM
pa28mays's Avatar
I just put Yukon in my 02 Screw 4x4 and they are at least as quiet as stock and the factory shims all worked perfect right in the middle of the tolerance range.
Old Jul 24, 2007 | 11:37 PM
8.8 rear end. no dot on stamp
