I want to re-gear... 4.11 or 4.56
Old Jul 19, 2007 | 08:26 PM
bigliftbb's Avatar
I have a 2006 Screw with 35" tires and a 6" lift. I'm still running my stock 3.55gears. I do a lot of freeway driving to work but I also tow a 22 ft travel trailer (about 6200 pounds loaded) about 10 times a year. I live in Arizona and do some pretty steep climbing in some areas. My truck seems to do fine on the flats but boggs down quite a bit pulling the hills. i didnt know whether to do the 4.56 gears for pulling or do the 4.11's and add an intake and programmer for my highway driving. Anybody with an 04-07 5.4 with a lift and gears had any problems with either size gears. I'm hesitant about doing 4.56 gears as I dont want my truck to be screaming cruising down the road to work. Thanks guys
Old Jul 20, 2007 | 01:53 AM
Hash278's Avatar
For 35" tires you should go with 4.56's. I think you should get the intake and the programmer anyways not just if you went with the 4.10's. I have 4.56's and its great.
Old Jul 20, 2007 | 09:16 AM
bigtruck311's Avatar
4.56
Old Jul 20, 2007 | 05:39 PM
Cuisi's Avatar
4.56
Old Jul 21, 2007 | 12:45 PM
GunnerB's Avatar
I also have 35' tires and a lift with the stock 3:55's. I was wanting to bump up to the 4:10's....Will the 4:56's be that much better than the 4:10's?
I'm not expecting an increase in mileage but, I am hoping not to lose a whole lot either.
..apologies for the hi-jack bigliftbb.
Old Jul 21, 2007 | 02:50 PM
bigdad8214's Avatar
Yes 4;56 will be that much better.
Old Jul 21, 2007 | 08:05 PM
greenbird's Avatar
There's also 4.30s if you want to hedge your bet.
Old Jul 22, 2007 | 12:59 PM
not if you have the 9.75 there arent
Old Jul 22, 2007 | 03:29 PM
Jordan not Mike's Avatar
4.10s would be waste of money with those tires.
You need 4.56 at the least.
Lots of us run (or ran, because I sold mine) run 4.10s on street-size tires.
Old Jul 24, 2007 | 05:39 PM
Knarf0486's Avatar
Do the 4.56's fit without any major modifications?
Old Jul 24, 2007 | 06:21 PM
The shop can just install them no problem. If you don't already have a LSD installed then now would be the time to do it as well, since the shop is already in there...you'll save a bit on labor and fluid
