Hubs or transfer case, that is the question
Old May 21, 2000 | 09:33 PM
R Holden's Avatar
Post Hubs or transfer case, that is the question
It's happened again, shifted into low range and hubs wouldn't lock. This makes the second time this has happened and when I finally get it in "four wheel drive", it's hard to get it out. The truck is a '95 F-150 with the 5.0, autohubs , and auto tranny. Anyone have any ideas. Thanks in advance
Old May 21, 2000 | 09:50 PM
redlariet's Avatar
Post
Sounds like an autohub almost blown out. Had that problem in my '95. There's a lot of plactic in there. If I had kept the truck, I would have tried anouther hub or manuel.
97 Lariet-sc-4.6-4x off road-auto-3.55 LS-
superchip-K&N-Poweraid-3"
pvc air box mod-Granetelli MAF
Old May 27, 2000 | 06:17 PM
Granpa's Avatar
Post
I think you will have to find out if the front drive shaft is turning or not when you have this problem. Could mark shaft, pull up a few inches, and see if the mark moves. Does this happen in 4High also?
