9.75 rebuild
Old Mar 14, 2007 | 08:41 AM
mike9254's Avatar
9.75 rebuild
Has anybody ever had any problem with your pinion seal leaking after the job? Looks like the leak is from inbetween case and metal flange of seal. Everything still sounds great have about 100 miles on no noise, checked fluid good, checked magnet (little stuff) wasnt able to power clean case so
I think it is left overs.
Old Mar 14, 2007 | 08:57 AM
crash_lucky13's Avatar
no man mine isn't leaking and i've put about 100 miles on it too.
tell you what,the 4.10 gears DEFINITELY make a difference. ESPECIALLY on the interstate. you hit it, no lag at ALL.
Old Mar 14, 2007 | 09:08 AM
mike9254's Avatar
Well I ended up gettin the wrong master set. Had the wrong front pinion and seal. I had to go to A.Z to get a new front bearing and Oriellys to get a new seal. The seal did not have the orange sealant around the edge, I think this is the problem. Lucky congrats on the gears. I can relate to that espeacially on the NM Intersate.
What opinions are there about the other items?
