9.75 lightining vs 9.75 04 and up rear end
Old Jan 15, 2007 | 10:26 PM
Huitt24's Avatar
I am trying to find the differences in these two rear ends. Are they both 31 splined axels? are the axel lengths the same? Are the brake caliper and e brakes the same? Reason I am asking is I am looking to convert my 04 F150 from 6x135 to 5x135 bolt pattern due to easyer wheel choices for drag radials. I am looking to replace the axels and rotors. Just seeing if anybody may have this info.
Old Jan 16, 2007 | 08:19 AM
BlueScrew4.6's Avatar
I'm almost positive the shock mounts on the axle are in different spots on the lightning axle and the 04+ axle. I know the 04+ axles have the outboard mounted shocks. Not sure on the brake setups between the two. Hope that helps.
Old Jan 16, 2007 | 08:24 PM
MitchF150's Avatar
Couldn't you just swap out the axles themselves then? Assuming they are both 31 spline....
Well, I guess you would have to see if the axles where physically the same lenght as well..
Sorry, I don't know the exact answer for ya on that one!
Mitch
Old Jan 16, 2007 | 08:46 PM
Oops, I misread the question. I thought you were asking about the whole rear assembly.
Old Jan 16, 2007 | 10:30 PM
Huitt24's Avatar
ya Iwas just wondering if anybody had any idea on axel length and spline. I know the outer bearings and seals are the same between the two, I just dont know if the track is the same. If the track width is the same then more than likely it would just be a axel swap. Thanks for the replys
