What size socket do I need?
Old Jan 14, 2007 | 12:19 PM
tbzep's Avatar
What size socket do I need to remove the front hub? It's bigger than anything I have and I already have the truck out of commission with other maintenance. I'm going to have to walk to town to get a socket because my wife is out of town. I want to get it right the first time.
2000 F150 4x4 ABS
Old Jan 14, 2007 | 12:23 PM
On my 03 2wd abs, To pull the rotor off the spindle, just get a big pair of channel locks, and twist out with it. The nut wasnt that thick, or deep of a nut, maybe like 1/4" max thickness. Does this seem at all like yours?
-Patrick
Old Jan 14, 2007 | 12:34 PM
tbzep's Avatar
-Patrick
I'm taking off the whole hub which has the integrated bearing. It's got a big 'ole nut (technical term) about 3/4" thick that holds the hub.
Old Jan 14, 2007 | 01:04 PM
Bubbadewsky's Avatar
I use a 1 7/16 it's a little loose but I do not have the correct metric size. This size will work
Old Jan 14, 2007 | 01:14 PM
tbzep's Avatar
Thanks! Time to get my walking shoes on.
Old Jan 15, 2007 | 01:44 PM
JMC's Avatar
JMC
25 Year Member
It takes a 35mm socket.
JMC
Tip: Leave truck on ground and loosen nut. Keeps axle from turning. If it is already in the air have someone press on the brakes.
JMC
