how to remove front hubs
Old Dec 2, 2006 | 12:45 PM
motokorte's Avatar
99 f150 5.4 4x4 I think i may have a bad wheel bearing, as something is making noiise. I had to beat the old rotor off, and i would have thought that the hub would pull off also with the nut off. i had to use a sledge hammer to get the rotors off. so is there anything holding these hubs on?
thanks for your wisdom
Old Dec 2, 2006 | 01:15 PM
Steve83's Avatar
That nut only holds the CV stub axle in the hub, which holds the bearings in place.
If you have 4WABS, remove the dust shield & sensor BEFORE removing the 4 bolts on the back of the steering knuckle (110-150 lb-ft). As you pull the hub out of the knuckle, make sure you PUSH the stub axle back through at the same rate so the CV boot/joint are not overextended.
Don't reuse that rotor if you beat on the friction surfaces.
Old Dec 2, 2006 | 01:39 PM
motokorte's Avatar
thanks steve, thats where im at. Id like to get bigger diameter rotors,as ive got 31in tires. but i dont want to pay triple.
Old Dec 2, 2006 | 05:01 PM
Steve83's Avatar
31s are nothing (barely bigger than stock) - certainly not enough to justify the expense & trouble of changing the size of the brake system. That would be a MAJOR modification, and depending on your local laws, you might have to get the truck re-certified. It's not a project for a weekend mechanic. In fact, not many pros would do it, except maybe as part of a complete axle swap.
When you find your brakes won't stop your 44s, THEN think about better brakes.
Old Dec 3, 2006 | 08:25 PM
F151's Avatar
And if the rotors came off that hard (as mine did), the hub will be worse. Get fresh can of PB Blaster and start spraying.
Old Dec 4, 2006 | 02:14 PM
GIJoeCam's Avatar
I had to pound the rotors off mine... hubs went a few months later. The three bolts on the back of the spindle are all it takes. The hub pretty much fell out at that point (gentle tapping from the back).
-Joe
Old Dec 4, 2006 | 08:59 PM
Steve83's Avatar
"Falling out" is kinda scary... They should have a LITTLE interference.
