Gears for my Expedition.
Old Jul 11, 2006 | 10:24 PM
Night5talker's Avatar
Hello. I have a 97 ford Expedition I just had it lifted and put some 39.5-13.50-20
tires on it Just woundering what gear ratio would get it back to where stock ratio and tire combo would be... Thanks for the help....
Old Jul 12, 2006 | 06:24 AM
jhoparmy's Avatar
Welcome to the forum. Depending on the specifics of your Expedition, you can only get 4.88's as the lowest gear. If you have the 8.8 rear axle then you can go all the way to the 6's of you want, but you can't get that ratio for the front and if you have a 9.75 then 4.88's is your limit, unless I'm just not looking in the right spot. You need 5.13's to get back to stock. Hope this helps.
Old Jul 14, 2006 | 02:57 PM
Thanks alot for the Help....
