Rear axle clicking.....
Old Jun 27, 2006 | 01:43 AM
ROLLINGon38'S's Avatar
When i'm off road or on a bumpy part of the road there is a clicking sound coming from my axle. So i jacked it up and took off the tires, and when i pull and push on the hub the hole axle move 1/4 in. or more. It does this on both sides. Is this something i should worrie about, and how do i fix it... Thanks
Old Jun 27, 2006 | 03:25 PM
GIJoeCam's Avatar
If you could push the axles in 1/4", the c-clip retainers would fall off and tha axle shaft would pull back out. I'm quite sure that the movement you're experiencing in the axle shafts is quite normal, otherwise, the axle shaft would have fallen out already.
The clicking can be coming from a whole lot of different parts. It could be as simple as the hitch drawbar rattling around in the receiver. Without some more information, it's going to be a little difficult to pin this one down.
-Joe
Old Jun 27, 2006 | 05:04 PM
well i know for a fact it's my axle, because i jacked it up and took my tires off.. And i could see it move....And i dont have a hitch on my truck anyways....thanks
Old Jun 27, 2006 | 05:48 PM
GIJoeCam's Avatar
OK, but again, the in and out movement of the axle shafts on a c-clip axle is 100% normal.
Old Jun 27, 2006 | 06:11 PM
Ok well thanks... so there is nothing to worie about, i just have never heard this on any other truck...
Old Jun 28, 2006 | 11:00 PM
ajbuick's Avatar
Exclamation
what year and model of truck? 8.8 rear or 9" 1/2 0r 3/4?ton could be a few things i have had the same experince and have gone through a lot of trouble shooting.you have any more info?
Old Jun 29, 2006 | 11:45 PM
It's a 1997 f 150, I think it has the 9" in it, and i guess it's a 3/4 ton, cuz it's a 150....
Old Jun 30, 2006 | 05:46 AM
GIJoeCam's Avatar
If it's a 97F-150, then it's either an 8.8 or a 9.75. If it has the Sterling 10.25, then it's an F-250 LD (AKA F-150 7700 lb). It's NOT a Ford 9".
Old Jun 30, 2006 | 11:45 AM
chester8420's Avatar
Mine does that same clicking crap too. It's a leaf spring clip thingy. I'm just too lazy to fix it.
Old Jun 30, 2006 | 08:44 PM
ok well i'm not to sure... but it's not the 10.25 i know that, so i will go with the 9.75...
Old Jun 30, 2006 | 08:46 PM
yeah i know for a fact mine is in the axle, But my leaf springs are all out of wack, but i know thats not where the clicking is coming from...
