Finding out the Gear Ratio for 97 F-150 and Compatibility
Old Jun 22, 2006 | 10:07 PM
brandonacoleman's Avatar
Hello,
Here are the numbers off of my 97 f-150 xlt. It's automatic, 2wd.
S 869B R
3L55 88 6F26
Could someone tell me how I would get the gear ratio, and what other models may have a compatible rear end?
Brandon A. Coleman
Old Jun 22, 2006 | 10:30 PM
Dr. Franko's Avatar
What is the axle code from the sticker on your door jamb?
Old Jun 22, 2006 | 10:36 PM
Quintin's Avatar
Originally Posted by brandonacoleman
Hello,
S 869B R
3L55 88 6F26
Brandon A. Coleman
S869BR - This is the factory code used for that axle assembly. If your dealer were to order you a complete axle, this is the part number they'd use.
3L55 - This indicates that you've got a limited slip (the L) axle, with a 3.55 axle ratio. An open 3.55 axle would just be "355," 3.73 would be "373," and so on.
88 - This is an 8.8" axle. "975" means it's a 9.75" axle, "80," for an 8" axle, etc.
6F26 - This is internal coding used to determine what plant that axle was built at and when.
Old Jun 23, 2006 | 05:47 AM
The axle code is H9.
Brandon A. Coleman
Old Jun 23, 2006 | 05:52 AM
Quintin,
You are the man! Appreciate it man.
Brandon A. Coleman
Old Jun 23, 2006 | 06:35 AM
Hello,
How would I find out, besides opening up the cover, if it is a 31 spline?
Brandon A. Coleman
Old Jun 23, 2006 | 01:32 PM
subford's Avatar
Hello,
Brandon A. Coleman
It is a 31 spline and also the 6F26 means that it was made at the Sterling Plant on the 26 of June 1996.
6 = year
F = month (A=1, B=2 ..... there is no 'I' in the sequence)
26 = day of month
