Clutch noise
Old Mar 3, 2000 | 05:24 PM
Road Runner's Avatar
Post Clutch noise
When I press in my clutch pedel it squeeks and is driving me nuts. Is this normal sound is definetly comming from inside transmition.
Any ideas on how to make it stop would be apreciated.
1998 F-150 4.2 W/Mod's
K+N air filter,K+N Oil Filter, Redline synthetic motor oil-Transmittion oil-Differential gear lube, Vortex single in duel out rear exit exaust, 4.10 gears,5 speed mtl,265-75r16 Bridgestone dueler AT, Hellwig anti sway bar rear, Add a Leaf springs, brush guard, nearf bars, Pioneer stereo W\Planet Audio speekers,Superchip
Old Mar 6, 2000 | 03:24 PM
Bill_Aquino's Avatar
Exclamation
No it's definately not normal, if it's still under warranty take it back. Good Luck
Old Mar 6, 2000 | 04:56 PM
hobbit's Avatar
Post
Does it squeek the whole time the pedal is depressed or just when the pedal is pressed and released? If it squeeks the whole time the clutched is engaged then it may be the throw-out bearing, if only during pedal movement then it may only be the linkage making noise. In either case take it in to get looked at. Your signature says you have a 98, it should still be covered.
Old Mar 6, 2000 | 10:57 PM
Shifter's Avatar
Post
Sounds like the clutch slave cylinder needs replacing. I had it done twice on my '98.
There are other posts on this elsewhere on this message board. Do a search first under "all open forums" before posting new threads, okay? Try this thread I found for you with the search engine: https://www.f150online.com/f150board...ML/000283.html
Black 2000 SC XLT short-box. 4.2 V-6, 5-speed, 3.55 Limited Slip. Side steps, CD, remote entry, FORD box liner. Add-ons: Older Windstar driver's side wiper blade (with the air scoop, because I don't slow down when it rains), back-up beeper, "f150online.com" sticker and snazzy Tweetie Bird floor mats.
My third F-series: '73 F-100, '98 F-150 and '00 F-150. Great trucks!
[This message has been edited by Shifter (edited 03-06-2000).]
Old Mar 7, 2000 | 09:55 AM
Post
The noise happens when i press or release the clutch pedel only.
Old Mar 7, 2000 | 10:00 PM
Shifter's Avatar
Post
Yup. That's it. When you push in or let out the clutch. I thought it was something I could lube but it's inside the clutch. Something to do with clutch dust dropping on the shaft of the slave cylinder. There's an upgraded slave cylinder out now. My Y2K doesn't squeak. Have the job done while it's on warranty and insist they do a search for bulletins from Ford to ensure they have the latest slave cylinder. Don't let them install an old one from stock unless they assure you it's the latest model. Otherwise, you'll be back for a clutch re-and-re and that's expensive if you have to pay for it.
Old Mar 17, 2000 | 10:19 AM
defacto's Avatar
Post
I've noticed that when I have the clutch out I hear something like a low vibration (or so it sounds). When I push the clutch in, the vibration or noise seems to go away, almost as if someone turned down a volume **** and it fades to no sound (does that makes sense?)
Is this a normal sound? It is quite quiet, but it's there.
98 F150-XL, Black
2WD 4.6L 5spd. Windsor Triton
RegCab, Shrt WB, Styleside 3.08
Air, Rear Slider, Ford Duraliner Boxliner, Ziebart rustproofing
HAWK Plus Bedcap, profile+ wrap-around bug deflector,
Tint: #4(5% light) RearCab & Bedcap Windows
#2(35% light) Cabside Windows
My Site
www.geocities.com/SiliconValley/Port/3091
Old Mar 19, 2000 | 01:05 AM
Granpa's Avatar
Post
defacto: When you hold in the clutch pedal, you are disconnecting the input shaft of the trans from the flywheel. So the input shaft stops, therefore, no sounds of the shaft and its gears turning, nor sounds from the bearings supporting it. I think every manual trans I've had has been quieter with clutch pushed in.
Old Mar 19, 2000 | 10:33 AM
defacto's Avatar
Post
thanks Granpa, I had a feeling it was nothing to worry about, but since this thread was here I figured I'd ask. If it gets any louder then I'll worry about it.
98 F150-XL, Black
RegCab, Short WB, 3.08
My Site
[This message has been edited by defacto (edited 03-19-2000).]
Old Mar 22, 2000 | 09:25 PM
Shifter's Avatar
Post
Don't worry about it, defacto.
Old Mar 22, 2000 | 09:42 PM
fakefvc's Avatar
Angry
mine also squeaks when I press the clutch in. I made a post about this a month ago. the guys here told me it's nothing to worry about. I hope there's nothing to worry about.... if so, help.
Ford vs Chevy
www.fordvschevy.com
Moderator: Road Kill, Mustang vs F-bodies
2000 White F-150 Sport 4.2L 5-speed,3.55 gears
MODS K&N, Flowmaster 40 series.
superstang97@yahoo.com
Old Mar 30, 2000 | 05:58 PM
Spartan's Avatar
Post
Well, I have the squeak too... It's definetly the dust because it only does it after driving for a while, and only when pressing/releasing the clutch, took a look under the truck... I *was* going to lube it with some white lithium lube stuff (as recommended by a mechanic friend of mine), but closer inspection revealed nothing I could see moving so I guess it's internal.
I'm gonna go next week and ask for a *new* slave cylinder. Think I'm outta warranty though, any knoweledge on the price shifter?
97F150 XLT SC 4x4 Flairside 4.6 V8 5sp Dk Toreador Red, 3.55LS
ARE tonneau cover, p255/70rx16 tires (came w/235), Superchip
Pioneer CD w/4 Polk Speakers, skid plates
bed liner, side window deflectors, reese hitch, K&N air filter
40s-2chamber Flowmaster, Bosch +4 spark plugs, rustproofing
Better Built Stainless nerf bars
heavy duty shocks
Old Apr 17, 2000 | 08:17 PM
Y2K 7700 4x4's Avatar
Post
I have not looked at any (damned tri-focals), but have seen other instances where there's a nylon bushing at the pedal pivot -- and those plastic things get dry and squeak. There's a special plastic lubricant (don't use WD-40 - it seems to make things worse) that works pretty well -- and molybdynem disulfide (sp?) grease has worked for me in the past.
Y2K™
XLT SC SB 5.4L 3.73LS
