Front Axle bearings
Front Axle bearings
I have a '97 4x4 and was wondering if anyone's ever changed the front axle bearings? I have changed the rear bearings and seals but didn't know if the front is same basic setup. One concern I do have is none of the parts store web sites list the seals.
If you have the IFS you need a wheel bearing hub assembly. Look up on Autozone.com. PN 515017 for Rear Wheel ABS and PN SP550200 for 4 wheel ABS. If you have the older syle F-150 the bearings, inner and outer, should be less than $40.00. Figure another $20 for seals.
JMC
JMC
