Differential leak
Old May 22, 2006 | 04:54 PM
Polydorus's Avatar
Differential leak
I have a two wheel drive, 1999 F 150, 4.2 L V-6 and I noticed a spot of oil on the differential cover Saturday. Looks like the gasket is failing and will have to be replaced. I been trying to check the oil level and can't get the plug out. I cleaned off the area with a wire brush and applied some penetrating oil but was unable to get it to turn. There isn't much room to work without a hoist and the 3/8 extension has slipped out a couple of times. I don't need to drive it this week and would really like to take care of it myself. Any suggestions would be appreciated.
Thanks,
Mike
Old May 22, 2006 | 05:01 PM
srf177's Avatar
You Probably tried this already, First spray with a good lube, like PB Blaster, WD 40 works but not as well. Then using your 3/8 drive give it gentle wacks with a hammer. This should loosen it up, Make sure your using a good name brand 3/8 drive, fits always better. Also replace your cover, its cheap insurance and you wont go thru what I did. Replaced gasket and cover had a small pin hole, had to do the whole job over. Good Luck. Scott
Old May 23, 2006 | 10:02 AM
Polydorus's Avatar
Thanks Scott, I have been using PB Blaster. I tried your suggestion but the extension keeps slipping out. The hole in the plug appears to be slightly elongated, maybe 3/8 by 7/16, and not very deep. I've probably made it worse but the metal isn't bright so it been that way for awhile.
Where did you get a new cover?
Mike
