How to ?
Old May 15, 2006 | 04:36 PM
JollyWhiteGiant's Avatar
How to ?
OK, sunk my truck down this weekend, (see post and picts in Off roading). Since the water was up over the front diff I probably need to change it out. Is there a how too or can someone tell me how to and what I need to do it. Sorry, I can fix things OK but have limited knowledge of repairing vehicles.
Old May 22, 2006 | 12:28 PM
bigtruck311's Avatar
it is easy, you will need to remove the front diff cover, and clean it all up, then you will reinstall it with some silacone gasket maker, then you will fill it back up on the filler bolt till the fliud comes out, i would also spend $17 or so on a repair manaul at the local parts store just so you will have it for the futer, it will go more in depth and make it easer for you, good luck
